Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Temperature dependent material properties.
3 REPLIES 3
369 Views, 3 Replies
It looks like I should be able to use temperature dependent material propeties for stress analysis of a pressure vessel.  Is that true?  Thanks.
3 REPLIES 3
S.LI
I believe so.
After the model is in simulation environment, both shell and solid elements support temperature dependent material models.
If this response answers your concern, please mark it as "solved".
in reply to: S.LI
Does the material library have temperature dependent material properties or do I have to find a source and enter them myself?  Thanks.
S.LI
I bet you need input it by yourself.
