Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Surface contact, single part analysis?
2 REPLIES 2
drpalo
419 Views, 2 Replies
Good morning all,
Can a part have surface contact with itself? For example, a structure imported as a solid CAD model that buckles onto itself but does not penetrate itself?
Thanks.
Autodesk Product Design Suite 2016
Dell Precision T5610
HP Z800 Workstation
2 REPLIES 2
xli
in reply to: drpalo
If you are making a MES model, make the surfaces of contacted portion not exactly matched, then in MES surface contact UI you would be ale to define the contact pair of same part/surfaces.
If you use LSS, you probably also have to make the contact portion slightly seperated and then manually define some gap elements there to simulation the contact.
-xli
zhuangs
in reply to: drpalo
If MES is used, in the general surface-to-surface panel, you can define the contact pair:
(1) if you know the two surface ID (such as 1, 2) of the surfaces in the same part, you can define the contact pair as
Part/surface 1 with part/surface 2
(2) otherwise, set part with part
