Discussion Groups
Simulation Mechanical and Multiphysics
Active Contributor
drpalo
Surface contact, single part analysis?
219 Views, 2 Replies
04-18-2011 07:52 AM
Good morning all,
Can a part have surface contact with itself? For example, a structure imported as a solid CAD model that buckles onto itself but does not penetrate itself?
Thanks.
Please use plain text.
Employee xli
Employee
xli
Re: Surface contact, single part analysis?
04-18-2011 08:24 AM in reply to: drpalo
If you are making a MES model, make the surfaces of contacted portion not exactly matched, then in MES surface contact UI you would be ale to define the contact pair of same part/surfaces.
If you use LSS, you probably also have to make the contact portion slightly seperated and then manually define some gap elements there to simulation the contact.
-xli
Employee
zhuangs
04-20-2011 12:43 PM in reply to: drpalo
If MES is used, in the general surface-to-surface panel, you can define the contact pair:
(1) if you know the two surface ID (such as 1, 2) of the surfaces in the same part, you can define the contact pair as
Part/surface 1 with part/surface 2
(2) otherwise, set part with part
