Good morning all,
Can a part have surface contact with itself? For example, a structure imported as a solid CAD model that buckles onto itself but does not penetrate itself?
Thanks.
If you are making a MES model, make the surfaces of contacted portion not exactly matched, then in MES surface contact UI you would be ale to define the contact pair of same part/surfaces.
If you use LSS, you probably also have to make the contact portion slightly seperated and then manually define some gap elements there to simulation the contact.
-xli
