Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Surface Pressure/Traction not applicable on surface
2 REPLIES 2
falkmassmann
751 Views, 2 Replies
I´m working on the Autodesk Simulation Workshop here to get familiar with the program.
http://engineeringexploration.autodesk.com/
I´m having a trivial problem with the cantilever beam in Section 2. Actually I should apply
a surface pressure of 2 psi on one of the surfaces on the beam but it doesn´t let me.
Obviously the selection preset goes to "surface", but everytime I want to apply the pressure it says I´m not
selecting the right positions or Load that is applicable.
I´m at a loss, this is a very simple task to do with Inventor FEA, somehow it seems to be a heck of a problem in ASM 2013. I´ve applied SP1 and SP2 but still no change. Thanks in advance
Cheers Falk
2 REPLIES 2
AstroJohnPE
in reply to: falkmassmann
Hi Falk,
My only thought is that the element type has not been set. Without knowing the element type, the software does not know whether a pressure load is allowed or not. (For example, truss elements do not have a pressure load.)
You can assign the element type manually, or mesh the model and the software will set the element type automatically.
falkmassmann
in reply to: AstroJohnPE
Hey John,
thank you for your advice, you were right on the money. After fiddling around a bit I figured it out.
Still a bit unexpected but of course makes sense. I would have expected ASM to give me an error when I specify the
elemet type wrong after I applied a pressure load. Anyways, problem solved.
Cheers Falk
