From your attached first picture, a velocity boundary condition was applied on the surface of the tube; however, the second picture shows the whole pipe is in an enclosure.
It needs to note that the velocity boundary condition is valid on external boundary, but not appropriate for any internal surfaces like in this case. To take care velocity BC on internal surface, one needs specify internal fan boundary condition on the surface. Internal surface always has surface pairs which have two surfaces in contacted parts, user can pick either one of them, then right click to select fan boundary condition and select type to "Internal" and Operation to "Fixed velocity", finally specify the wanted velocity magnitude and direction.
(Refer to attached image for internal fan/vBC settings)
For the warnings of “Converge with stagnation due to oscillation”, it is common and acceptable that the real fluid has some oscillations if it turns in relative complicated geometries.
