Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Message 1 of 11
aaron.smeenk
671 Views, 10 Replies
Start up error
Im running windows 7 64bit and everytime I try and open simulation I get an error stating "Unhandled exception". Ive uninstalled and reinstalled the program and even redownloaded it and reinstalled the new download. Ive tried running as administrator and running in vista compatability mode but have never been able to get the program to start up. any suggestions?
10 REPLIES 10
Message 2 of 11
S.LI
in reply to: aaron.smeenk
Do you mean Autodesk Simulation MP 2013 or other packages/versions?
If this response answers your concern, please mark it as "solved".
Message 3 of 11
aaron.smeenk
in reply to: S.LI
Yes, sorry for not mentioning. simulation mp 2013
Message 4 of 11
S.LI
Can you see all these files installed on disk, usually at C:\Program Files\Autodesk\Simulation 2013?
Can you try any exe in that folder by commandline, such as arun4.exe?
BTW:
Is your system in English, or others?
Message 5 of 11
aaron.smeenk
in reply to: S.LI
my system is in English
I can navigate to that directory and see files and when I run arun4.exe from the cmd I get a list of switches that its looking for after the start command but I dont know what any of them mean to use one and try again.
Message 6 of 11
aaron.smeenk
in reply to: S.LI
here is a screen shot of the cmd
Message 7 of 11
S.LI
The arun4 output looks no problem.
Can you run "algframe.exe" in cmd?
It should start the GUI.
Also, there is a batch file called RegAll.bat.
It's helpful to re-run this batch file.
Message 8 of 11
aaron.smeenk
in reply to: S.LI
the algframe starts the program just like clicking the icon and then gives the same error. I ran that batch file it said somethign about registering all the dlls and what not and then reran the algframe and had the same error
Message 9 of 11
S.LI
How about your system? memory size, disk size etc.
One of previous posts mentioned video card sometimes matters.
Message 10 of 11
aaron.smeenk
in reply to: S.LI
the computer is an asus g73
6GB RAM
RADEON HD 5870
327GB free hard drive
I run Inventor 2013 no problem
Message 11 of 11
I have the same problem with 2014 version. Have you found the way to fix it?
Evgen Tulubensky
PhD-student
Facebook | VK | LinkedIn
