Quick question - am I right in thinking that the tool previously known as 'Surface Knitting' (with the ability to split faces inside Sim Mechanical) is no longer included, and the current options are the 'Virtual Imprinting' option and the 'Split Surfaces on Import' option only? I am simply looking to split a cylindrical bearing face (without using the CAD application) and cannot find the option.
Many thanks for your help.
Luke
Solved by AstroJohnPE. Go to Solution.
Hi Luke,
You are correct that "Surface Knitting" was renamed to "Surface Splitting" since that was more descriptive of the changes to the model that the user could see. (Who cares what the software does "behind the scenes" as long as it works, is fast, etc. ) But otherwise I do not remember ever having an option for the user to choose to split a surface or not. Perhaps you are referring to one of these features:
You always have the option to change the surface number of lines after meshing the model. This can bet a little confusing because you are really dealing with two different features (a 3D CAD surface versus a "surface" formed by element faces). Version 2014 made a change so that the CAD surfaces were visible instead of just the mesh surface. In some cases the CAD surface can partially obscure the mesh lines (depending on the curvature). I don't know if the surface selection is based on the CAD surface, the mesh lines, which one you click on, or if it doesn't matter. In case there is a priority, use the "View > Appearance > CAD Surfaces" to toggle the visibility of the CAD surfaces.
Also, if you have Autodesk Inventor Fusion, you can modify the "simulation" CAD model without changing the original CAD model. So, you could either split the surface physically, or insert a new part so that you can use "surface splitting" to cause the surface to be split. This concept is described on the page titled "Surface Splitting" in the Help documentation.
Let me start by pointing out that for a bearing load ("Setup > Loads > Bearing"), the surface can be an entire cylinder or any portion! The software will only apply the load to the half in the direction that you specify, so there is no need to split the surface. Of course, if you are using a different type of load, it may be necessary to split the surface.
The option to change the surface numbers is done as follows:
Note that there may be some commands that work only on original CAD geometry and may not work if the lines are changed manually. Commands such as "Draw > Design > Centroid Creator", "Setup > Constraints > Pin Constraint", and "Setup > Loads > Bearing" may be limited to original CAD geometry only -- I don't remember.
Also, the perimeter of the new surface may not be unform/straight since the region being changed is based on the randomness of the mesh.
