Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
SolidEdge import problem?
1 REPLY 1
398 Views, 1 Reply
Has anyone else had problems trying to import a part into Algor from SolidEdge? The problem I have is that some surfaces of the model are not imported correctly. They are there in the model tree under Part -> Surfaces, but they cannot be seen in the model window itself.
It's only a solid model part, without anything strange. I've tried importing the .SAT file and sending it directly from SolidEdge, with the same results.
Björn
1 REPLY 1
S.LI
Hi, Björn, Do you think this is an import problem, or just a display issue? Is any surface load or contrain able to be applied on the surface (by right-clicking the surface in the tree view)? Could you mesh the model and do some analysis? Thanks.
If this response answers your concern, please mark it as "solved".
