Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Simulate Deformation of Metal when heat is applied?
1 REPLY 1
laranjo123
296 Views, 1 Reply
Is it possible to simulate metal when is heat applied? Please help i'm new in Sim.Mechanical thanks in advance.
1 REPLY 1
zhuangs
in reply to: laranjo123
In Setup->Parameters->Thermal, you can select the source of temperatures, and then you need define the nodal temparature load curve index and default temperature.
-Shoubing
