Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Results Seem Off For Nozzle Analysis
1 REPLY 1
timsefton
307 Views, 1 Reply
Working on an analyis for a nozzel that uses an air amplification scheme.
The velocity magitude seems as though it is correct, but the flow rate through seems almost negative.
See pictures below - any thoughts are welcome.
1 REPLY 1
Joey.X
in reply to: timsefton
Just a remind the tips at inquiring flow rate in POST processor
- Change result to flow rate
- Select interested surface(s) only  or face(s) at interested elements
  (Never select nodes)
- Make sure result smooth is disabled
BTW, the negative flow rate is probably correct depending the inflow or outflow at selected surface(s).
Jianhui Xie, Ph.D
Principal Engineer
MFG-Digital Simulation
