Is there any way to increase the font size of the results? (i.e. von mises, displacement magnitude) I noticed in the the application options you can increase the size of the scale and the ucs icon, but I couldn't find anthing relating to the results scale. I've attached a pic with the exact area in question circled in red.
Adrian
Solved by ilyas_drawbridge. Go to Solution.
Hi Adrian,
Everything about the legend can be edited via Results Contours > Settings > Legend Properties. In this case, go to the Legend Properties tab inside the dialog and click on Font... You should be able to change the font size for the legend here.
Regards
Ilyas
Thanks Llyas. That is exactly what I was looking for! I appreciate it.
Adrian
Is it possible to change the default legend text size so that I don't need to come and change this each time? Thanks.
