Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Results Font Size
3 REPLIES 3
powder1742
706 Views, 3 Replies
Results Font Size
Is there any way to increase the font size of the results?  (i.e. von mises, displacement magnitude)  I noticed in the the application options you can increase the size of the scale and the ucs icon, but I couldn't find anthing relating to the results scale.  I've attached a pic with the exact area in question circled in red.
Adrian
3 REPLIES 3
Hi Adrian,
Everything about the legend can be edited via Results Contours > Settings > Legend Properties. In this case, go to the Legend Properties tab inside the dialog and click on Font... You should be able to change the font size for the legend here.
Regards
Ilyas
powder1742
in reply to: powder1742
Thanks Llyas.  That is exactly what I was looking for!  I appreciate it.
Adrian
adlerd
in reply to: ilyas_drawbridge
Is it possible to change the default legend text size so that I don't need to come and change this each time? Thanks.
