Simulation Mechanical and Multiphysics
New Member
Accepted Solution
Result view in MES
100 Views, 2 Replies
01-07-2014 03:22 PM
Hi
I'm performing a simulation of plane undercarriage in MES with high initial velocity.
Is there any way to hold the model from running away off the screen in result tab?
Peter
Please use plain text.
Valued Mentor
Re: Result view in MES
01-08-2014 02:09 PM in reply to: P.Mad
Hi Peter,
I can think of two methods, one that is fun but tedious, and another which is boring but easy :smileyhappy:
Fun but tedious
I am thinking of an analogy: a crash test. Instead of a stationary camera, you would like the camera to follow the object. So what you would like to view is the relative displacement, not the total displacement. I think the software cannot do that automatically, although perhaps there is some way to do it with the custom results. Otherwise, you could
  1. output the complete displacement results file to a text file ("Results Options > Other > Tools > Nodal Results Translator")
  2. Choose 3 nodes to represent the moving origin, X', and Y' axes.
  3. Calculate the displacements for all nodes at all time-steps relative to the X', Y', Z' coordinate system. I'm guessing you have a lot of data (many nodes and/or time steps), so the file size might be too large for Excel.
  4. Put the calculations back into the nodal results.
Boring but easy
Turn the displaced shape off ("Results Contours > Displacement > Show Displaced"). You can use the strain results to visualize the relative displacement over time, but you would not be able to show the displaced shape.
This gives me another idea. What would happen if the displacements (X, Y, Z) were replaced with the strain (XX, YY, ZZ) using the nodal results translator? If you did this, choosing the "X Displacement" would really show the XX strain, but that value could be used to show the displaced shape. I do not know if that would be meaningful or not.
John Holtz, PE
Mechanical Engineer
Pittsburgh, PA
16 years experience with Simulation Mechanical
New Member
01-10-2014 04:51 PM in reply to: AstroJohnPE
Dear John
Thanks for quick answer, the first option is what I'm looking for.
I have checked the Nodal Result Translator in Autodesk online documentation and I think I can write a simple C++ code to recalculate displacement.
I will share the source code for people with similar problem.
Peter
