I have a strange error that has occured twice in three days now. Suddenly, without any reason whatsoever I can't open Algor anymore. It just says that Algor is not registered correctly (see attached image).
I haven't had any problems at all with the registration, and then suddenly this pops out of the blue. The last time it happened, I opened one Algor window, and then when I tried to open the next, I got this error. There isn't any reason for it to happen since I hadn't done anything!
It seems to work by "repairing" the installation but having to do this every other day is very frustrating. Any ideas why this occurs?
Is it because of the beta version?
How's your 2011 version?
No, I stopped running the Beta version a few weeks back. This is the 2011 Pro edition with SP1.
I have had the same problem some days ago.
Fresh install of Algor Simulation 2011 SP1 on a new machine. No beta version before this install.
The only "strange" thing I have done before having this trouble it was the installation of DivX Plus Converter.
In my case it happened only one time (until now).
Regards
G. Barozzi
Hi, All,
Maybe you can try to post your installation-licensing problem at the following place.
They might provide more valuable help.
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
BTW: please post the solution here if your problem get solved. thx.
It happened again right now. I'll post it in the licensing/registration forum.
This issue happens when the registry of Algor is unregistered. The quick solution is, run "RegAll.bat" file in the install catalogue of Algor.
Hope it helps.
Tim
Simulation QA Engineer
