Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Message 1 of 9
504 Views, 8 Replies
Re: won't finish
report attached
8 REPLIES 8
Message 2 of 9
Royce_adsk
This is related to the Multiphysics package and not Simulation CFD.  Moving the post.
Royce
Royce.Abel
Technical Support Manager
Message 3 of 9
For a 24 x 24 x24 box with a blower at inlet - still issue with finishing. No error codes. Just increased mesh at inlet and blower outlet. will send pic of  model next....
Message 4 of 9
Goofy--- one model gives good solution and next model with all asame conditions wont finish. And I made sure all was same.
Message 5 of 9
Spoiler
Solution went back to "wont finish"
Message 6 of 9
John_Holtz
A quick question for you fdimpfel: If you run the same model twice in a row, does it stop at the same point?
You will probably need to provide an archive of your model in order for someone to figure out what is happening. Please see the post "Create, Post, or Provide an Archive of your model".
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Message 7 of 9
Is there a way to turn the outter model back on? I used the internal function to get the negative space and now want to view the results with the original model to make a presentation.
Fred
Message 8 of 9
John_Holtz
Just to clarify, the "outer model" refers to the solid parts which are not part of the fluid flow simulation. Right?
The Results environment can only display the parts that are included in the actual simulation: in this case, the fluid parts. So the obvious solution is to "photo shop" an image of the fluid results and the solid parts. Depending on how you want things to look, you may  be able to add a background image to the Results environment ("Results Options > View Settings > Background Image"), and show the results and solid at the same time. However, the background bitmap is a static image, and the model (fluid parts in this case) will be "on top" of the background regardless of the view orientation, etc.
John Holtz, P.E.
Autodesk, Inc.
Message 9 of 9
correct...... ok seems like a cutaway view might be able to show a good picture due to back view front view issue
