Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Radial Offset for Beams
3 REPLIES 3
B_A_T
1228 Views, 3 Replies
I am trying to put a radial offset on a bunch of beams and was curious if there is a way to do it? Basically I want the location of the beams to be further out radially than I have them drawn. I have tried using a center node but since I need to enter an I and J node, it would seem I would need to define these nodes all the way around the circle to get an accurate offset. Is this the case or is there some way I am missing?
Thank you in advance!
3 REPLIES 3
guozh
in reply to: B_A_T
Beam offset is used to define the offset of neutral axis. The offset values DX, DY and DZ for I and J node are supposed to be in global coordinate system.  Moreover, I think there is no local coordinate system support for beam offsets.  If you were trying to offset beams using any local coordinate system, it would not be feasible.
The best way is to redraw the lines (geometry model).
andrewdroth
in reply to: B_A_T
I would really benifit by being able to do this also.
For example. I have a round tank with a rim angle, I'd like to offset those beam elements radialy to properly represent the actual geometry.
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
madg1
in reply to: B_A_T
this is one serious drawback, ASIM people should address.
One workaround suggested by astrojohn was to use beam elements with high stiffness values to represent beamoffsets.I modeled a whole lattice structure using the above method.
madg1
ASIMM 2012
