Discussion Groups
Simulation Mechanical and Multiphysics
Valued Contributor
AndyWalker
Positive & Negative Max Principal Stress?
946 Views, 1 Replies
05-30-2013 03:31 AM
Can someone help me please.
What does the positive and negative max principal stress represent?
Is it tension and compression?
many thanks
andy
Please use plain text.
Valued Contributor
AndyWalker
Re: Positive & Negative Max Principal Stress?
05-30-2013 03:37 AM in reply to: AndyWalker
dont worry i found the answer:
Maximum Principal
This command sets the results display to calculate the maximum principal stress (S1) for displaying or data output. The principal stress can be displayed for element types with area (2D, plates, and so on) and volume (bricks). Positive (+) indicates tension, and negative (-) indicates compression. See Mohr's Circle for an illustration of this.
