Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Optimization Problem
0 REPLIES 0
Message 1 of 1
GersonMachado8699
319 Views, 0 Replies
I am having an issue concerning the utilization of the Optimization tool. When I press the Perform Design Optimization and press Analyze, I get the following message:
Model Name = C:\Users\yossef.didi\Desktop\testes ponte 45m
# of Design Variable = 4 # of Performance = 4
Optimization Method = 1 MaxIter = 20
MaxObjChange = 0.010000
** Design Variables **
Design Part# Property Lower Limit Current Value Upper Limit
** AISC Beam Section Type should be same for %d th design list !!
On the Design Optimization window, on Design Variable, all of my variables have been inserted by myself, and I don't know if that's normal.
Also, I put the Objectives/Constraints according to my needs, and at least that I think is correct.
Can someone help me to understand the error I'm getting and to make this optimization work?
Thanks in advance!
0 REPLIES 0
