I made an inventor model (2012) with an ipart I found on the web. After I cleaned up my inventor model, I uploaded it to Simulation (2012) and performed a solid mesh. Solid mesh failed; so I reverted to a plate mesh. The model solved, BUT it is treating my iPart as (2) parts! The only thing I can find is that Simluation takes the member to have 2x the amount of surfaces then it actually has. I revisited my inventor model and I have not found any duplicate parts, just the one iPart. Is there a way to address this issue? Does Simulation have a "model merge" feature that eliminates "parts INSIDE of other parts?" Has anyone experienced a similar failure?
-Kenny
Solved by AstroJohnPE. Go to Solution.
Hi Kenny,
When you did the "plate" mesh, do you mean a midplane mesh? My guess is that you literally used the Plate/Shell mesh, so what you did is create plate elements on the "outside face" of the solid and on the "inside face" of the solid.
For example, a solid model of a simple rectangular slab (something thin and large in the other 2 dimensions) has 6 faces.
Also see the page "Model Mesh Settings" in the wiki help.
