Im trying to add ISO 32 Hydraulic Oil in the materials library. i basically copied all fields from the "water" material and changed the values for Mass Density and Dynamic Viscosity. the problem arises when i try to select that material in my simulation tree. the new material does not show up in the fluids folder. the only way i can use a new material is by using the "customer defined" option.
can anyone provide a solution or some ideas on why i cannot get the new materials to show up?
