Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Net electric force on a part
1 REPLY 1
284 Views, 1 Reply
I am modelling a MEMS comb drive, and was looking to find the net electric force on one of the combs.  I made a simple model, as my model was too large to attach (even after compression, archiving, and zipping).  In this model, I am looking to find the net electric force (magnitude and direction) on the part named "Oscillator Comb".  Is there a method to do this?
Thanks for your help,
Mike
Model is attached, in a zip folder.
1 REPLY 1
John_Holtz
Hi Mike,
It's very easy! In the Results environment, you want to display "Results Contours > Electrostatic Force > Vector Plot".
Then select the nodes where you want to sum the forces, right-click, "Inquire Results".
On the dialog, set the summary drop-down to "Sum", and the adjacent field will show the sum of each vector component.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
