I would really appreciate some help in here.As my project has the invovement of hot air jet impingement on an iced surface(related to deicing of aircraft) i really want to know is it possible to do multiphase flow simulation on autodesk simulation multiphysics/cfd.
i checked some brochure but i am not sure. Please tell me Autodesk simulation has the capability of simulating multiphase flow or not.
i will look for an early reply.
thanks to all of you.
Depending on the physcal problem and assumption, if there are density changes (or multiple conbination of multiple fluid matrials) in hot air jet impingement problem, SIM-MP will not handle it, you can check SIM-CFD product.
