Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Move a remote load
2 REPLIES 2
drpalo
605 Views, 2 Replies
Move a remote load
Can you edit the xyz location of a remote load?
Thanks.
Autodesk Product Design Suite 2016
Dell Precision T5610
HP Z800 Workstation
2 REPLIES 2
John_Holtz
in reply to: drpalo
Dr. Palco,
You do not edit the location per se. The Remote Load command is really just a wizard to draw beam elements and add loads/constraints at the point. What you do is select the node and move to a different coordinate using the "Geometry > Tools > Point Move" command.
This command works on any node/vertex, not just remote loads.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
drpalo
in reply to: drpalo
This makes sense.
Thanks John.
HP Z800 Workstation
