Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Models disappearing
2 REPLIES 2
617 Views, 2 Replies
Models disappearing
I've been having some problems lately with my models disappearing. Either some parts, or the entire model seems to just disappear. They are still available in the parts tree to the left, but they're not anywhere in the results or pre-processor window. I've tried "enclosing" and zooming out, but they're just not there. Does anyone else have the same problem? This has happened mostly in the coupled steady-state heat transfer/fluid analysis.
/Björn
2 REPLIES 2
Yes I have been seeing this on Autodesy 2011 Algor.  When in transient heat transfer the model disappears from the window if I try to rotate with the mouse or zoom with the mouse wheel.  I can find no way to recover the model!  Is this a bug - I have never seen it before?  Bring back the old Algor code it was far less unstable!
Tony
Go to SURFACES under the disappeared part,
Select all surfaces (using CTRL), then right-click and select SHOW.
It should work.
