The results for a modal analysis you can be displayed for displacement magnitude, what exactly is this showing? In the attached example the displacement magnitude is 359mm yet the part is only 30mm wide x 90mm long so it is physically unable to move 359mm. Am I miss reading something?
Solved by shakeel.mirza. Go to Solution.
Hi Ed,
The displacement values given by a modal analysis are NOT to be interpreted as real displacement values.
This is logical as forces are not defined in Modal analysis, so there is no reference to calculate the intensity of load hence displacement.
The disp. values are to be interpreted as an indicator of relative displacement within your design (which point will displace the most as compared to the other points in the model).
The only output that have physical meaning from a modal analysis is the Frequency and the mode shape (again relative displ. and not absolute).
To calculate the real value of displacment, one will need to apply the forces with their real value+direction+variation along time ; hence a linear dynamic or MES should be carried out.
Hope this explains.
Shakeel
Shakeel
Thanks for the information, it makes much more sense now.
Regards, Ed
