Discussion Groups
Simulation Mechanical and Multiphysics
Valued Contributor
mechamania
Message: Use SSAP0G or SSAP0GC for models containing gap or contact elements
152 Views, 3 Replies
09-12-2013 01:24 AM
Hi
I'm using Simulation 360 pro.
So now and then I get this message when running analysis on the cloud:
"Use SSAP0G or SSAP0GC for models containing gap or contact elements"
When I try to run the same project later, it may run correctly, without error.
So it is not a problem with the project. Is this a capacity problem with the cloud servers?
Please use plain text.
Valued Contributor
mechamania
Re: Message: Use SSAP0G or SSAP0GC for models containing gap or contact elements
09-24-2013 02:25 PM in reply to: mechamania
This is the message I get:
Employee
PipePakPat
09-27-2013 01:13 PM in reply to: mechamania
Hi Cor,
This issue seems like it may be model dependent and I recommend to create an archive of the model and open a support case from within the Autodesk Subscription Center.
Pat
Pat Tessaro, P.E.
Customer Support Engineer
Autodesk, Inc.
285 Kappa Drive
Suite 250
Pittsburgh, PA 15238
Valued Contributor
mechamania
09-27-2013 04:34 PM in reply to: mechamania
I do not think it is model dependent. When I run the same model some time later, it may succeed.
It happens with all kind of projects. Simple simulations and complex simulations.
