Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
mechamania
289 Views, 1 Reply
Meshing problems
I'm evaluating Mechanical Simulation.
When meshing an assembly, I very often see that the progress bar is running to its maximum while not all parts are meshed yet (see picture).
The only thing I can do is click Close. The assembly is not meshed after that. Sometimes there is also an Error Report.
There is no other information about what could be wrong.
Any idea what is wrong?
1 REPLY 1
zhuangs
in reply to: mechamania
It seems that the mesh process is stuck at some points and does not finish.  If the mesh size is too small, you can increase the mesh size and try.
-Shoubing
