Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Meshing problem 3D solid
4 REPLIES 4
499 Views, 4 Replies
I have used simulation software in dynamic analysis of Reinforced concrete frame but while automeshing the bars and some parts of the frame cant be mesh and it ran out of meshing  however i removed the bars and then done the meshing without any problem.
can anyone help me please? i have watched the tutrial videos but i cant resolved it till i found this forum .. hope someone can help me .. thanks in advance 🙂
4 REPLIES 4
cieslak.maciek
Could you provide us with some more data? For example some printscreens of the structure?
in reply to: cieslak.maciek
hi thanks for respons.. i have face difficultis during automeshing.
Looking at the second image; the re-bars have very high aspect ratio relative to the rest of the model. This maybe causing you problems with the auto-meshing. You may want to consider using 2D beam elements to represent your bars.
noted about the beam elemnt. these are all integrated as Reinforced concrete beam. the Beam still has to be brick for analysising . can u help me out in solving it? i mean still the first part can not be meshed ... i have cheched almost everything.. soon or later my laptop will burn due to over processing!
