Simulation Mechanical and Multiphysics
Active Member
B_A_T
Meshing Error
153 Views, 0 Replies
12-19-2012 06:54 AM
I am trying to mesh something it is a decent size model, but nothing too out of the ordinary.
I keep getting this error on several models,
ecrt_tsx2tsy_Invoke
eht_OutofMemory
I have also gotten some system errors before while trying to mesh it, at the same point when it tries to verify the mesh
I am just trying to put on a surface mesh and seems to mesh fine but when it tries to verify the mesh I get this error.
This model does have a large amount of cyclic symmetry surfaces ~400 pairs wondering if this is the issue? but I have tried turning that off to see if it would mesh without luck.
I will add that there is no way i am running out of memory as the system i am running it on has 48GB of Ram and the model has an element size of less than 800,000 elements
Any help with this would be greatly appreciated
Thank you
Please use plain text.
