Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Message 1 of 1
B_A_T
385 Views, 0 Replies
Meshing Error
I am trying to mesh something it is a decent size model, but nothing too out of the ordinary.
I keep getting this error on several models,
ecrt_tsx2tsy_Invoke
eht_OutofMemory
I have also gotten some system errors before while trying to mesh it, at the same point when it tries to verify the mesh
I am just trying to put on a surface mesh and seems to mesh fine but when it tries to verify the mesh I get this error.
This model does have a large amount of cyclic symmetry surfaces ~400 pairs wondering if this is the issue? but I have tried turning that off to see if it would mesh without luck.
I will add that there is no way i am running out of memory as the system i am running it on has 48GB of Ram and the model has an element size of less than 800,000 elements
Any help with this would be greatly appreciated
Thank you
0 REPLIES 0
