Hello Everyone,
How could I mesh my model in Autodesk Simulation 2012 the same way Autodesk Inventor Pro 2012 does?
Basically, I have a somewhat complex assembly that if simulated using Inventor has a mesh that looks quite nice and simetric.
But, when I open the assembly in Simulation and I try to mesh it, the mesh is much heavier and not very simetric.
How can one mesh in simulation to have the same results given b y the meshing in Inventor? What are the parameters?
Thank you very much!
Solved by hupn. Go to Solution.
I am afraid you can not do that due to the different mesh engine in these two software.
But you do can change the mesh size and element types (brick or tet) for the CAD model in Autodesk Simualtion. These setting are set in Mesh -> 3D Mesh Settings.
You can try using tetrahedra mesh. And you may want to turn on the mid-side option for all tet mesh to get a more accurate soluiton.
hupn
Thanks for the Reply, everyone.
I'm getting now much more acquainted with the Simulation and things are getting much better!
Thanks again!
