Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
haolam
598 Views, 1 Reply
Mesh Convergence
Basing on the precision calculation method used in Algor, how do I know when the results have converged? the precision ranges from zero (best) to 5 (worst), but what is the standard acceptance of precision that the results should be based on so that I won't have to do mutiple runs with finer meshes to determine that the solutions have converged. Thanks.
Hao
1 REPLY 1
PipePakPat
in reply to: haolam
Precision does not consider the "significance" of the stress for which the precision is based.  For this reason, a poor precision may be indicated in a region of the model that possesses insignificant stresses.  I mesh convergence study requires no less than three different mesh sizes refined in the regions of interest to determine if the stresses converge or continue to increase which would indicate a singularity.  Singularities are addressed by altering the original geometry to include fine details such as filets or rounds or by applying loads or boundary conditions distributed over a consistent area instead of a specific single node.
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
