Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Mechanical 2013 - Measure function causes Crash
2 REPLIES 2
nosborne
468 Views, 2 Replies
I imported a small IGES file containing a few lines and arcs. When I use the "measure" tool the software crashes and corrupts the database so that it cannot be re-opened. I tried creating a few lines directly in Simulation and the same thing happened when I used the "measure" tool with that model. I have not had issues with it prior to version 2013. Anybody else have the same experience?
2 REPLIES 2
Sualp.Ozel
in reply to: nosborne
I am running Simulation Mechanical 2013 Service Pack 2 on a Win7 (64 bit) machine with 16 GB RAM and I do not experience a crash using the "Measure" tool in "FEA Editor" or "Results" environements
nosborne
I discovered that Service Pack 2 solves the problem (along with other issues I was experiencing). Thanks.
