Discussion Groups
Simulation Mechanical and Multiphysics
New Member
Measuring applied load for an object moving under displacement control.
92 Views, 1 Replies
10-01-2012 03:05 AM
I have a situation where I am modelling one bar moving at a constant displacement rate, pushing against a bending object. I want to know what load is having to be applied to move the bar at it's constant rate. Is there some way to extract this value? I have been using the magnitude of the reaction force on the underside of the bending object, but I'm not sure if that is correct.
Thanks for any help.
Please use plain text.
Employee
Sualp.Ozel
Re: Measuring applied load for an object moving under displacement control.
10-10-2012 08:47 AM in reply to: ucfbmrc
In the Results interface, change the result type to Reaction Forces.
Select the surface (more specifically all the nodes on that surface) to which you have applied the surface prescribed displacement. Right click, inquire results, and change the operator to “Sum”.
Best Regards
Sualp Ozel, PE
Product Manager
Digital Simulation
Autodesk, Inc.
