Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Material Library Manager: damping value - where is this used?
1 REPLY 1
DonaldR.Culp7481
399 Views, 1 Reply
When I select a material in the Material Library Manager, "damping" is one of the available entries under General Properties. For what type of analysis would the material's damping be used?
Don C.
Tags (1)
1 REPLY 1
Hi Don,
This is material damping used in MES analyses.  Typically, this value is left as zero, unless physical testing has been performed to determine this value, then it is still very small, such as ~"0.05".  I think this correlates to "Tangential damping" is described in research articles I have previously read.
Just confirmation that it is best to leave as zero unless you know otherwise 🙂
Pat
Pat Tessaro, P.E.
Premium Support Specialist – Simulation
Autodesk, Inc.
6425 Living Place
Suite 100
Pittsburgh, PA 15206
