Hi I ve got node out of range error while using MPC to simulate bolt between 2 mating parts
This is the sequence of steps i folloew
I modelled a beam element for Bolt
For Multiplier, I gave the dia of the bolt top area and for vertex id i selected the top node of beam element and the nodes around the mating part
DOF I gave Y translation
i applied beam pre load to the beam element
while executing it gave this node out of range error
Please clarify where it went wrong and advice me right way to model MPC
Hi noormohamed,
You will probably need to supply an archive of your model; hopefully someone can run the analysis to find out what the problem is. See the thread "Create, Post, or Provide an Archive of your model".
Your description sounds reasonable, and the software doesn't care if your equation is wrong from a physical or engineering standpoint, so it is just about impossible to know what the problem is with the analysis. (I cannot think of an equation in which you would use the area of the bolt for the multiplier in the MPC equation. You should provide the equation that you have entered and explain your logic for it; then we can explain if it is reasonable or not. Please indicate what directions are X, Y, Z since your figure does not show that.)
P.S. Is there a reason that you are using MPCs instead of using the bolt wizard ("Mesh > CAD Additions > Bolt")? It would be a lot easier than writing multiple MPC equations to "connect" the top of the bolt to each node around the hole.
