Hello Everyone,
I am experiencing the following problem. I installed Autodesk Simulation Mechanical 2015 with SP1 and I can't run models whose files are situated on a windows network mapped drive.
The message I get is quite simple: Analysis Failed. The log files are not so verbose. I appended the log file of a given analysis so that someone interested can check. The thing is, the job process cannot access the network share.
Please note that, if I copy all the files to the local computer, the analysis works.
I am not a noobie and I know what is happening. The job manager is a service that runs on the background and gets asked by the graphical application to analyse a model on a given file. And it, since it is running with another user, gets access denied.
The things I did were:
1- I added EnableLinkedConnections=1 registry key as stated in here: http://technet.microsoft.com/pt-br/library/ee844140(v=ws.10).aspx
I now can access the share using, for examble, Excel if I ask it to run with elevated privileges (run as administrator)
It still did not work.
2- I changed the user that runs the "Autodesk Mechanical Simulation Job Manager Local Service" to run with the user I am logged in, which clearly has access to the file.
The question is:
1- Is it possible to disable the job manager option thing and go back to the way it was before?
2- If not, how can I make it work with my beloved shared folders?
Thanks!
LOG FILE
<event when="20140717T095636" level="warning" source="getConfigurationSettings" code="0" process="CloudExec-win-x64.exe:4144" message="config file: C:\Program Files\Autodesk\Simulation 2015\Simulation Job Manager\dsspjobclient.config"/>
<event when="20140717T095636" level="warning" source="getConfigurationSettings" code="0" process="CloudExec-win-x64.exe:4144" message="config file: C:\Program Files\Autodesk\Simulation 2015\dsspjobclient.config"/>
<event when="20140717T095638" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5128" message="OpenUsing Command Line : cmd /C set ALGOR_ROOT_2015="C:\Program Files\Autodesk\Simulation 2015\" && start "C:\Program Files\Autodesk\Simulation 2015\AlgFrame.exe" "N:/EMASA/008 - Itaquerao/05 - Revestimento Lateral N-S/4 - INVENTOR/Poste.fem""/>
<event when="20140717T095638" level="warning" source="createJob" code="0" process="SimJobManager.exe:5236" message="openUsing was provided, but request was not signed"/>
<event when="20140717T095638" level="warning" source="createJob" code="0" process="SimJobManager.exe:5236" message="openUsing will be ignored"/>
<event when="20140717T095638" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5128" message="Thumbnail file name : N:\<CHANGED BY ME>\4 - INVENTOR\Poste.ds_data\1\Thumbnail.png"/>
<event when="20140717T095638" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5128" message="Create job ( V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212 ) successfully at createJob"/>
<event when="20140717T095638" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5128" message="Starting job: V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212"/>
<event when="20140717T095638" level="info" source="CloudExec.EventFirer" code="0" process="CloudExec-win-x64.exe:5128" message="Start event firer (thread: 3312/cf0)"/>
<event when="20140717T095638" level="info" source="CloudExec.JobStarter" code="0" process="CloudExec-win-x64.exe:5128" message="Start job (thread: 3568/df0)"/>
<event when="20140717T095638" level="info" source="CoCloudExecEventHander::OnJobStatusChanged(DS number : 1, status : 11)" code="0" process="AlgFrame.exe:4188" message="Enter."/>
<event when="20140717T095638" level="error" source="queryTask" code="1000" process="CloudExec-win-x64.exe:5128" message="task not found"/>
<event when="20140717T095638" level="info" source="ujm" code="0" process="SimJobManager.exe:5236" jobid="V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212" message="scheduled job - V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212"/>
<event when="20140717T095638" level="user" source="ujmc" code="0" process="SimJobManager.exe:5236" jobid="V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212" message="Job [Poste | 1] submitted for solve"/>
<event when="20140717T095638" level="info" source="localjobmanager" code="0" process="dssp_jobServer.exe:1156" jobid="V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212" message="launched job"/>
<event when="20140717T095638" level="info" source="CoCloudExecEventHander::OnJobSubmitted(DS number : 1)" code="0" process="AlgFrame.exe:4188" message="Enter."/>
<event when="20140717T095638" level="info" source="CloudExec.Monitor" code="0" process="CloudExec-win-x64.exe:5128" message="Start monitoring (thread: 3468/d8c)"/>
<event when="20140717T095638" level="info" source="CoCloudExecEventHander::OnJobStatusChanged(DS number : 1, status : 8)" code="0" process="AlgFrame.exe:4188" message="Enter."/>
<event when="20140717T095638" level="info" source="CloudExec.JobStarter" code="0" process="CloudExec-win-x64.exe:5128" message="Start job exits with 0"/>
<event when="20140717T095638" level="warning" source="getConfigurationSettings" code="0" process="AlgorLocalLauncher.exe:656" message="config file: C:\Program Files\Autodesk\Simulation 2015\Simulation Job Manager\dsspjobclient.config"/>
<event when="20140717T095638" level="warning" source="getConfigurationSettings" code="0" process="AlgorLocalLauncher.exe:656" message="config file: C:\Program Files\Autodesk\Simulation 2015\dsspjobclient.config"/>
<event when="20140717T095638" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Command line: "C:/Program Files/Autodesk/Simulation 2015/AlgorLocalLauncher.exe" V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212 2ffd92a7-82a7-4195-bcb2-b16665af1910 C:\ProgramData\Autodesk\Mech\ws\de1a23fd-f71f-435e-88da-51834864e212\2ffd92a7-82a7-4195-bcb2-b16665af1910"/>
<event when="20140717T095638" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Launching job"/>
<event when="20140717T095638" level="info" source="ujm" code="0" process="AlgorLocalLauncher.exe:656" message="dssp_jobserver_port is set. dssp_jobserver will use port 43912"/>
<event when="20140717T095638" level="info" source="config" code="0" process="AlgorLocalLauncher.exe:656" message="using product name:Mechanical Simulation Job Manager"/>
<event when="20140717T095638" level="info" source="getUJMCRegValue" code="0" process="AlgorLocalLauncher.exe:656" message="registry key:SOFTWARE\Autodesk\Mechanical Simulation Job Manager"/>
<event when="20140717T095638" level="info" source="ujm" code="0" process="AlgorLocalLauncher.exe:656" message="set to use system configuration proxy"/>
<event when="20140717T095639" level="error" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="AgsdbGeneralAccess.Open failed with -103 at PreSolveUtility::OpenAGSDB"/>
<event when="20140717T095639" level="error" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Failed to read fem file."/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Geometry compiling for linear is started"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="succeeded in CompileGeometry"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="succeeded in UpdateKnodeData"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="CheckForAdvance for linear is started"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="succeeded in CheckForAdvance"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="failed in CheckForVoltAdvance"/>
<event when="20140717T095639" level="error" source="FileUpdater" code="0" process="AlgorLocalLauncher.exe:656" message="Failed to open index file: N:\<CHANGED BY ME>\4 - INVENTOR\Poste.ds_data\1\LastDelta.txt at SetLastIndex"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Solver started"/>
<event when="20140717T095639" level="info" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="Solver failed with the return code 255"/>
<event when="20140717T095639" level="error" source="AlgorSaaSLauncher" code="0" process="AlgorLocalLauncher.exe:656" message="AgsdbGeneralAccess.Open failed with -103 at PostSolveUtility::OpenAGSDB"/>
<event when="20140717T095639" level="info" source="localjobmanager" code="0" process="dssp_jobServer.exe:1156" jobid="V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+de1a23fd-f71f-435e-88da-51834864e212" message="job finished normally"/>
<event when="20140717T095643" level="info" source="CoCloudExecEventHander::OnJobStatusChanged(DS number : 1, status : 4)" code="0" process="AlgFrame.exe:4188" message="Enter."/>
<event when="20140717T095646" level="info" source="CoCloudExecEventHander::OnJobStatusChanged(DS number : 1, status : 4)" code="0" process="AlgFrame.exe:4188" message="Enter."/>
Hello Everyone,
Stopping the service and forcing it to run using that .bat file did not do the trick.
Now the application, when run using the .bat file cannot create local folders
****, HOW DOES ONE GIVE ACCESS TO THE NETWORK SHARE FOR THE JOB MANAGER?!
<event when="20140717T102056" level="error" source="ujm:TaskManager" code="0" process="SimJobManager.exe:5328" message="Download limit set to:0"/>
<event when="20140717T102059" level="warning" source="getConfigurationSettings" code="0" process="CloudExec-win-x64.exe:3852" message="config file: C:\Program Files\Autodesk\Simulation 2015\Simulation Job Manager\dsspjobclient.config"/>
<event when="20140717T102059" level="warning" source="getConfigurationSettings" code="0" process="CloudExec-win-x64.exe:3852" message="config file: C:\Program Files\Autodesk\Simulation 2015\dsspjobclient.config"/>
<event when="20140717T102100" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="OpenUsing Command Line : cmd /C set ALGOR_ROOT_2015="C:\Program Files\Autodesk\Simulation 2015\" && start "C:\Program Files\Autodesk\Simulation 2015\AlgFrame.exe" "N:/EMASA/008 - Itaquerao/05 - Revestimento Lateral N-S/4 - INVENTOR/Poste.fem""/>
<event when="20140717T102100" level="warning" source="createJob" code="0" process="SimJobManager.exe:5328" message="openUsing was provided, but request was not signed"/>
<event when="20140717T102100" level="warning" source="createJob" code="0" process="SimJobManager.exe:5328" message="openUsing will be ignored"/>
<event when="20140717T102100" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="Thumbnail file name : N:\EMASA\008 - Itaquerao\05 - Revestimento Lateral N-S\4 - INVENTOR\Poste.ds_data\1\Thumbnail.png"/>
<event when="20140717T102100" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="Create job ( V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+15685992-5784-4f43-bc13-474c91aeb77a ) successfully at createJob"/>
<event when="20140717T102100" level="info" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="Starting job: V1+LAN+localhost+dls-dsim-simmech-2015-solver-desktop+local+15685992-5784-4f43-bc13-474c91aeb77a"/>
<event when="20140717T102100" level="info" source="CloudExec.EventFirer" code="0" process="CloudExec-win-x64.exe:5124" message="Start event firer (thread: 2896/b50)"/>
<event when="20140717T102100" level="info" source="CloudExec.JobStarter" code="0" process="CloudExec-win-x64.exe:5124" message="Start job (thread: 2848/b20)"/>
<event when="20140717T102100" level="info" source="CoCloudExecEventHander::OnJobStatusChanged(DS number : 1, status : 11)" code="0" process="AlgFrame.exe:5040" message="Enter."/>
<event when="20140717T102100" level="warning" source="ujm" code="0" process="dssp_jobserver.exe:2564" message="failed to execute sql with - attempt to write a readonly database"/>
<event when="20140717T102100" level="error" source="ujm" code="0" process="dssp_jobserver.exe:2564" message="failed to begin transaction"/>
<event when="20140717T102100" level="error" source="ujm" code="0" process="dssp_jobserver.exe:2564" message="failed to start transaction"/>
<event when="20140717T102100" level="error" source="UploadFolderEndPoint" code="0" process="dssp_jobserver.exe:2564" message="Failed to create folder LV1/.dls-dsim-simmech-2015-solver-desktop-DB"/>
<event when="20140717T102100" level="error" source="HttpRequest" code="500" process="CloudExec-win-x64.exe:5124" message="request failed with 500
POST http://localhost:43912/storage/folders/v1/user/local/service/algweb
request headers:
Content-Type=application/json
x-dssp-create-folder=LV1%2F.dls-dsim-simmech-2015-solver-desktop-DB
response headers:"/>
<event when="20140717T102100" level="error" source="uploadFileEx" code="500" process="CloudExec-win-x64.exe:5124" message="Folder LV1/.dls-dsim-simmech-2015-solver-desktop-DB does not exist and cannot be created"/>
<event when="20140717T102100" level="error" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="WriteDatabaseToCloud failed with 500 (Folder LV1/.dls-dsim-simmech-2015-solver-desktop-DB does not exist and cannot be created) at Activate"/>
<event when="20140717T102100" level="error" source="CloudExec" code="0" process="CloudExec-win-x64.exe:5124" message="Activate failed at CloudJob::Schedule"/>
<event when="20140717T102100" level="error" source="HttpRequest" code="500" process="SimJobManager.exe:5328" message="request failed with 500
POST http://localhost:43912/storage/folders/v1/user/local/service/dsspws
request headers:
Hi 184640,
This issue has been resolved in the 2016 release of Simulation Mechanical, I strongly recommend upgrading to that version.
Andrew
