Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Issue in Analysis - SIM MECH 2014
2 REPLIES 2
sriramsheval
438 Views, 2 Replies
We just got upgraded to 2014, for first two analysis the program ran well.
Later the Element definition can't be defined, so material also can't be defined.
see the picture below, all the red line in browser window are not defined (analysis type is also red)
please anyone help me to solve this issue
2 REPLIES 2
AstroJohnPE
in reply to: sriramsheval
Hi sriramsheval,
Assuming the usual things did not work, such as exiting the software and restarting it, rebooting the computer, and so on, my guess would be that the name of the model or one of the folders where the model resides is causing a problem. Make a really simple folder on your hard drive (such as C:\junk) and do a "File > Save As" in Simulation Mechanical. Place the model in the simple folder and name the model test.
Does this work?
sriramsheval
in reply to: AstroJohnPE
Hi John,
Thank you.
I tried Saving As the file in another location, it didn't work.
But after i RESTART the system, now all works fine.
Thanks Again
Sriram
