Im new to both Inventor Pro 14 and simulation Mechanical,
whenever I attempt to run "Launch Active Model" through Inventor I receive the following error:
"The DLL "AlgConfig-win-x64-dll" was not able to be located on behalf of "D:\Program Files\Autodesk\Simulations 2014\ClmpAlnv-win-x64.dll" contact tenchincal support"
Im running on a windows 8.1 machine installed via admin and compatability mode for (Win 7) and I have upgraded to SP1 for Inventor.
for example the models in the Parts Archive found here:
http://engineeringexploration.autodesk.com/content/module-2-elastic-plastic-material-analysis
i receive the crash, but also cannot open the part file in simulation as i receive a blank screen with the word ready in the bottom lefthand corner.
Any help would be appreciated
Ishaak
Here are some ideas:
Hi Mr. Holtz
Thanks for replying,
I have checked and the file exists and is currently in my Autodesk Simulation directory is this the correct place? Or should it be under another folder?
Im unsure as to what page you mean by registering the file? Ive registered the product once I had downloaded it via the website i.e. my serial number etc was emailed to me.
If I open simulation directly and open the part it eventually opens and looks correct. Attempting to enclose fit all - the model zooms out and centers itself (I'm assuming that this is what the function is meant to do).
Does this mean that the issue lies within the inventor side of the programme?
Thanks for the help
Regards
Ishaak
