I am doing a Static Stress with Non Linear material models on a bar.
The dimensions are 10 x 10 x 100 mm.
The left side is totally fixed and on the right side there is a force of 50000 N.
I know that is to much, but my analysis parameters are set into 100 steps.
So I am trying to see when the bar breaks. I want to know at which step te bar can't handle the force any more.
Ohter settings are:
Von Mises with Isotropic hardening.
My material is:
So when I start the analysis, it goes to step 52.
Then the Von Mises stress is 284 N/mm²
So I want the know if the part broke or not, or did it already break.
What is the error that Autodesk Simulation Mechanical gives when the part breaks.
Solved by AstroJohnPE. Go to Solution.
Hi Thomas,
Simulation Mechanical does not calculate the breaking of parts. The stress can increase to infinity (in theory, usually not in a nonlinear analysis because something will happen numerically that prevents the analysis for reaching infinite stress).
It is your job, as the engineer, to decide what criteria means that a part will break. Is it when the calculated stress exceeds the ultimate strength? Is failure due to fatigue? Impact? Fracture?
