I am performing steady coupled fluid and thermal flow analysis. I know at the two inlets their is an initial temperature of 30 degree celius. At the outlet I know I have a velocity of 200mm/s. I know I have a heat source of 50 on the shaft. When I run the analysis, I am not getting any results, all the results are zero. I need the get the pressure, velocity, flowrate, and temperature at different parts of the body. Can you help me? I can not upload the file ach file because it too big. Do you have a drop box?
