Dear All,
My name is Hiandy Tanudiredja from Indonesia and I need a help from all of you.
The product from Autodesk which I use is ONLY Autodesk Inventor 2011. I am an autodidact and my level of using it is still beginner.
What I want to achieve as my final target, by your help, is to show to my customers a drawing showing the reduction/degradation of heat (temperature) on a product. Later on I will describe the product.
I was informed that Autodesk product which can fulfil my wish is Autodesk Simulation Multiphysics. I have already installed it with version of 2013. Unfortunately, I am not quite familiar with this product. By doing try-and-try-again way, I got a result. Though, this is near-to-my final target, but it is still far from perfect.
However, I can not put the flie with extention .fem on attachment to show to you. Would you please let me know how to do it.
Now, let me explain about the product:
I have already made an assembly, see file “Exp Joint SSP2 No Cooler Assembly rev1”
Now, my questions are:
A.Is it possible to perform a heat transfer simulation on that assembly? Let us give a pre-condition to that application: the temperature inside the duct is 300 ˚C and the temperature at the outermost part (back up flange) is about 50 ˚C.
B.If the answer for A is yes, would you kindly show to me step-by-step procedure to get that simulation.
C.If the answer for A is no, then you can take all soft parts and we will get only metal part. Then please show how to get the simulation.
If you have questions, please do let me know.
Look forward to receiving your solution.
Thank you
ht
Hello Hiandy,
The only file you attached was a drawing file (.IDW) which indicated some files were missing when I tried to open it. So we do not have all of the details about your model that you intended to provide.
If all of the parts are in contact with each other so that there are no air pockets in the analysis, then a simple "Analysis > Change > Type > Thermal" simulation will give the results that you want. There are a number of example heat transfer simulations in the documentation.
If you want to provide your Simulation Mechanical model for the Discussion Group to review, please read this post: "Create, Post, or Provide an Archive of your model".
Hi AstroJohnPE,
Thanks for your reply.
I am the very first time using Autodesk Simulation, so I am really sorry for all mistakes. Please give 1 or 2 days to fix them.
Hope you are still there to help me.
Thank you
ht
