Discussion Groups
Simulation Mechanical and Multiphysics
Gravity and meshing issues
233 Views, 4 Replies
04-09-2013 05:33 AM
Hi everybody !
I'm a beginner on this software and I have some issues trying to apply gravity on my model. Of course I did all the official tutorials before posting my thread.
Explainations :
I start to modeling my very simple model on Inventor Fusion : a plate, then I import it on Autodesk Simulation Multiphysics 2013.
On ASM13, I apply gravity on my model (with the apple icon, defined as earth gravity) I mesh the plate and I block Tz DOF on two opposite edges.
When I run a static analysis with linear materials I got neither constraints nor displacements.
I know I missed something but I'm unable to figure it out.
The other point I wanted to discuss is why when the soft remesh a complex model the process is much longer than when I mesh on by myself ?
When I ask details while the process is running, it displays "Closing Remaining Voids".
A sentence I didn't see during my first meshing.
Thank you for your Help.
Regards.
Please use plain text.
Distinguished Contributor
madg1
Re: Gravity and meshing issues
04-09-2013 12:47 PM in reply to: Ju_brl
 can you explain a little bit more about what you mean in this sentence?
madg1
ASIMM 2012
04-09-2013 11:52 PM in reply to: Ju_brl
I just found my mistake.
I didn't activate the gravity in my analysis options...
My apologize, thank you for your help.
However, for my second issue I think it won't be that simple...
Regards.
04-10-2013 09:52 PM in reply to: Ju_brl
By default, the initial mesh by pressing Generate 3D Mesh only meshes the outer surface of your CAD model. When you press Run Simulation, the software will then generate the internal mesh by filling the voids inside your outer surface mesh prior to running the simulation. The interior mesh my take some time depending on the quality of your outer mesh. In my opinion, what causes the interior mesh to slow down is when you have large transitions of mesh size. If it takes too long, you may try to uncheck the Use Automatic Geometry Based Mesh Size Function inside  Mesh>3D Mesh Settings>Options>Model to get a more uniform mesh on your model.
Regards
Ilyas
04-11-2013 02:47 AM in reply to: ilyas
Thank you for your answer and tips !
Regards.
