Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Gravity Load Cases: Different Orientation of Gravity in each load case
3 REPLIES 3
scudelari
550 Views, 3 Replies
Hello Everyone,
I wanted to check the impact of gravities on different directions for my model by using load cases.
When I set the gravitational direction, it changes the X, Y and Z multipliers for all the load cases..
It seems that, for gravity loads, it is only possible to create load cases that would have different intensity, but not different directions.
Is it possible to do what  intend?
Thanks a lot!
3 REPLIES 3
S.LI
in reply to: scudelari
I think you are right, the direction of gravity is fixed in one DS, no matter what the loadcase is.
The only cheap way I know is to do it with multiple DSs.
If this response answers your concern, please mark it as "solved".
scudelari
in reply to: S.LI
S.LI
Don't be sad, please. 🙂
Workaround is better than no solution, isn't it? 🙂
Best,
