Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Frequency response error - Node number out of range
3 REPLIES 3
1830 Views, 3 Replies
When I'm trying to use a modal analysis to run a frequency response, I keep getting the error message "Node number out of range". I have checked and double-checked the node number, but it's correct. I have made sure to define a frequency index, and set the excitation load properly. Any ideas on what the problem might be?
This is the log file:
 Autodesk Algor Frequency Response
 Version 2011.00.00.0111-W64/X64 12-MAR-2010
 Copyright (c) 2010, Autodesk, Inc. All rights reserved.
 Restart Analysis
 **** Frequency response analysis (restart)
      Options executed are:
      processing ...
 **** Model Unit System Settings:
       Unit System              : Custom
       Force                    : N
       Length                   : mm
       Time                     : s
       Temperature (Absolute)   : deg C (K)
       Thermal Energy           : J
       Voltage                  : V
       Current                  : A
       Electrical Resistance    : ohm
       Mass                     : N*s^2/mm
 **** OPENING TEMPORARY FILES
      NDYN = -5
      COPY: C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\2\ds.s7  TO C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\3\ds.t7
      COPY: C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\2\ds.s8  TO C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\3\ds.t8
      COPY: C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\2\ds.s9  TO C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\3\ds.t9
      COPY: C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\2\ds.s12 TO C:\Users\Public\Documents\Projekt\Teroc AB\1089\CAD\Eigenfrequency\Tower_full_reduced.ds_data\3\ds.t12
      DATE: MARCH 10,2011
      TIME: 01:07 PM
      INPUT MODEL: ds
 **** BEGIN NODAL DATA INPUT
      111904 NODES
 **** Checking modal file node consistency
      111904 NODES
 **** EQUATION PARAMETERS
      total number of equations      = 413358
      bandwidth                      = 1
      number of equations in a block = 2208
      number of blocks               = 188
 **** Hard disk file size information for processor:
      Available hard disk space on current drive =1064532.500 megabytes
       No. of equations    (NEQ) =     413358
       Bandwidth         (MBAND) =          1
       No. of eqs./block  (NEQB) =       2208
       No. of blocks    (NBLOCK) =        188
Error. node number out of range.
Thanks.
Björn
3 REPLIES 3
Nevermind, I assumed that it was the vertex number that was supposed to be used, not the node number.
Now I ran into another problem. When I try to start the analysis, I get an error message (see attached screen). What does this mean?
S.LI
I think it's very possible that non-english characters in your model path cause this error.
Please try to copy your model to "c:\temp" and have a try.
If this response answers your concern, please mark it as "solved".
Yeah, copying everything to a new folder worked. I don't understand why, though; I have no non-english characters in the path. Must've been some strange file permission issue.
