Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Fluid Flow Symmetry
2 REPLIES 2
319 Views, 2 Replies
Fluid Flow Symmetry
I am currently running a fluid flow analysis through a circular pipe. The model is 3D with half symmetry applied (180° model). If I have an inlet velocity of 1m/second for the whole 360° model, what velocity value do I apply to the 180° half symmetry model?
2 REPLIES 2
AstroJohnPE
If you are saying that the inlet velocity is a uniform 1 m/s across the entire inlet face, then you can specify a velocity of 1 m/s. This is independent of whether you have the entire 360 degrees modeled or any fraction.
Perhaps you were thinking about the flow rate in which you would need to apply half of the total flow rate to a half symmetry model. 😉
in reply to: AstroJohnPE
Excellent!
Thanks John.
 I just wanted a check on it before I ran the full model.
