Hi Everyone,
I am currently trying to simulate a pulley in Inventor, I have been told to use "static analysis" instead of "modal analysis". I would be of the assumption that a pulley would be undergoing dynamic loading hence the "modal analysis" would be applicable. Could someone please guide me in the right direction here. And if i was to use a modal analysis could you please tell me what type would be the most accurate to use in this situation.
Thanks in advance.
A desperate Martin
Sorry guys, I nobody does know the exact answer could you please guide me in the right direction on where to get some information i can read up on. Thanks
Although pulley's are in motion, they can normally be dealt with as a static problem assuming acceleration and angular momentum is negligable (which is normally the case). The only other case in which I can think of which would prove static analysis to be insufficient is if you are performing fatigue analysis.
Hope This helps
