We've been fighting a recurring issue where the solver errors out.
simplified test
Modal analysis with load stiffening
Using previously successful modal analysis results
4 rigid elements (single part) sharing common node
Remote force applied to common node
The error reads
error: rigid element number: 2 node already assigned:165
We get a bunch of these errors.
When the rigid definition is replaced by beam elements, all is well and solves. (this is what we've done in the past)
I am trying to help another fellow who has to work with rigid elements.
Any ideas?
Solved by AstroJohnPE. Go to Solution.
If you are able to run the analysis using linear static stress and modal (without load stiffening), then it sounds to me like a software bug in the modal with load stiffening. Here are two options:
John,
Thanks for the reply.
The PA team did in fact confirm that it was a 2014 issue (2013 as well), and that they would pursue the fix when the development cycle came around to it.
Unfortunately the gentleman will have to go back to the client or go to another solution because rigid are part of the contract requirements.
We've used beams successfully, but I want to follow up more specifically with your notes on them. Thank you very much for all the help here.
