Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
335 Views, 1 Reply
Error during Solving
Hai All,
 **** Sparse Matrix Assembled
 **** Invoking Parallel BCSLIB-EXT Sparse Solver...
 **** Load Cases 1
      BCSLIB-EXT solver memory status:
      in-core memory requirement (MB) =          795.65
      minimum memory requirement (MB) =           96.90
           user specified memory (MB) =         1144.76
       available physical memory (MB) =         1144.76
        available virtual memory (MB) =         4706.98
      memory currently allocated (MB) =          795.65
Error occurred with module: C:\Program Files\Autodesk\Simulation 2014\srunx.exe
Am getting the above error, i just copied a Scenario(which i got results properly).
I just chabge the load value, and i get the above error
Please help me to solve
Sriram
1 REPLY 1
KubliJ
Hi Sriram,
Unfortunately without additional information, we can only guess what went wrong.  You said you changed one thing; double check the change you made, maybe a typo is causing the problem due to some unrecognized character.  What is the load you modified, pressure, nodal load, thermal?   What kind of elements, bricks, beams, plates?  Upload the model if you can, screen shots would be helpful.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
